Well.... I had a fuel fitting leak, on the pass side, rear of the fuel rail. Not a wrench in my collection would reach the fitting, much less, turn the #$%^ thing. So I made one:
Took an old offset (drop) 1/2, 9/16ths box end. Took a 3 cornered Jewelers file, slooowly filed away 1 flat of it at about the 2 o'clock position, so it would slip over the fuel line. That puppy fits right on the fitting, you can get about a third of a turn with each movement. Life is Good.
(I used the file so as not to destroy the temper)
Thought I'd pass it on
