how to remove a hpop
bears4x4
grease monkey
katy texas
How do I remove the hpop on the 7.3, I have heads, hpop and turbo lower housing left
dieseltech1
tampa fl
you have two high pressure oil lines that take a special tool or just unscrew fittings two studs or bolts then pull access cover off of front houseing there is a bolt remove that and the gear is a wedge fit
the special tool ain't that special... I've done it with a GM fuel filter tool...
