HPOP o-rings?
black_cloud_stroker00 said:
Does anyone know the exact size of these and is there a special material they need to be made of?
Did you see THIS THREAD that CHPMustang started about HPOP o-rings? Dont know it that will help you or not.-popcorn
The CAT shop won't know the size lemme get you the part number I ended up using:sweet
SDD member "Mudwhistle" which is a CAT mechanic hooked me up with the right O-ring :notworthy ;tu
The O-ring size should be according to the CAT book;
1.980 mm cross section diameter
11.890 mm inside diameter
