I have a massive shimmy in the front end when i brake and a clunking noise over bumps
onefastt
Mississippi
In the front end. also when i get under the truck I can move the driveshaft up and down at the center support bearing. its about a quarter inch of play. Is this normal?
Wood County Tx
details young man
year, 2wd etc, lb short bed, etc etc. mileage on it , lift, tire size-popcorn
as far as the center carrier, is it teh bearing itself or the rubber encasement
the rubber dampeing encasement should be able to move to absorb vibrations and flex..:sweet
steering stabilizer, ball joints tie rods,
onefastt
Mississippi
sorry powerboater
its a 2001 f-250 7.3 4x4 lariat short bed crew cab 150,000 no lift stock tires with a monsterous brushguard/bumper on the front. thanks in advance for the help. also just replace the shocks to no avail. it is the rubber isolator. the sshimmy is so bad it almost rattles you out of the seat.
