I have been busy lately
haulin8or
Hotlanta, GA
X looks great! :thumbs
I thought PullRight made a hitch for the X out of the box? What did you have to modify? I almost went with one but opted for the Hensley Arrow that mounts on the trailer. How do you like the PullRight?
spindrift
Central Jersey
FMt...Truck looks great.:thumbs Now for a few questions. Rancho doesn't make a stabilizer for the Ex, or is the one you installed bigger? What improvement did you see?
Didn't you have an HA before the Pull-Rite, or am I confused...yet again? Have you towed with the Pull-Rite yet?
You been busy there Tim! Bout time you got the clearance roof lamps done too:thumbs
The fuel cooler I'd to hear more about in the near future from ya.:cool:
Yeap Rancho manufactures steering stabilizers for the Excursions but I spent about half on the ProComp ES2000 for our Excursion.The difference when going over railroad crossings with the ProComp over the dwarf stock unit is excellent:cool:
ProComp & Rancho stabilizers roll off the same production line,the only difference is the decal you want:D
FordMastertech
Ford Guru
Burlington CT
I never had a Hensley Arrow hitch and not many of them were around when I got the Pull Rite hitch for my 87 Ford van. The Pull rite hitch was taken off the Van when I bought the Excursion and I fabricated some brackets to get it to fit the 4X4 Excursion. I had Pull Rite send me some information on the Excursions hitches and the pictures they had showed the hitch almost on the ground and they said it will not fit a 2WD Excursion, I could see why after looking at the pictures. With the brackets I made it's sits up nice and high and I retained the stock trailer hitch. As far as towing with it you feel no sway or push from the trucks passing or should I say the ones I am passing, LOL:D . It takes some getting use to as the trailer really cuts to the inside when tuning so you need to make some really wide turns but get to scare the crap out of the people sitting at the light when you cut it back in at the last second. :eek: I have turned my 31 foot travel trailer around in a 2 lane road with this hitch. The tires on the trailer don't like it too much and there was some pretty strange looking skid marks left in the road by the inside trailer tires. It really turns some heads when I pull a maneuver like that. :hail :cop The biggest thing I don't like about it is when you want to move the trailer over to one side or the other you need to pull up a lot further than you would have to with a more normal type hitch. In some camp grounds this can be a real PITA.:dunno If I remember correctly I bought it brand new in 1992 for $550 which is a deal for what they are going for now.
:thumbs :bootyshak :guns: :jerk: :cool:
Rancho makes a steering stabilizer for the Excursions, the number is RS5412 and they list a high performance one, RS5410, which is the standard one for the Super Duty's. They also list a RS5413 for the 05 Excursions which doesn't fit the 05 Excursions, it fits the 05/06 Super Duty's new front end which the Excursions don't have. The Super Duty's high performance one, RS5406 is around 3 inches longer, bigger diameter and has a larger shaft diameter. I just ground the axle mount slightly, inserted a sleeve in the bushing to get it from 5/8 inch to 12 mm, a washer on the top of the bushing and mounted it to the axle bracket. For the tie rod end all that was done was to slide the mounting bracket over to the drivers side and use a standard 5/8 shock mounting stud to mount it to the bracket. The RS5406 doesn't come with any hardware so you will need to find the sleeve, washer and shock stud. All the original hardware was reused to mount it to the axle and the bracket to the tie rod. :confused:
The handling is a lot more precise with fewer steering corrections when on the highway. I don't get any more steering wheel jerking when hitting pot holes or when driving over uneven surfaces.
:burnit :roflmao :clap: :woo :wow
FMT
Crusin350
D Dub
Troy, IL
'05 Headlights
Do those fit right up to the older style trucks (1999), do you have to change the wiring or anything. I like the look of the front end like that!
good work!!!
FordMastertech
Ford Guru
Burlington CT
'05 Headlights
good work!!!
Fit right in, some what but some trimming of the header panel is required. You have to cut all the old headlights mounting points off and open up the hole in the header panel for the 05/06 light buckets to fit in. The new lights have a bigger back side to them so this trimming is necessary. The first side took about 2 HR to do and the other side took 15 minutes.
The wiring connectors need to be changed, 9007 to 9008 bulbs, and the wiring pigtails are big bucks from Ford.
I recommend using THIS HARNESS. Its a lot less money, better quality, gives the head lights full voltage and eliminated a lot of wire splicing.
FMT
