I want more power
GOEGLEINBROS
Wright Cicty, MO
I'm not sure what else I can do without spending big money on a diff turbo or propane. What's the most power that anyone has heard with a custom tune on the diablosport? I mean 300 rear wheel is respectable, right? I plan on contacting them this week, but I wanted to see if anyone has a custom tunes or has any other info maybe 100hp tune is the limit.
CSIPSD
Bend, OR
If you go with a costom chip your not going to see much more then 325 or so... But your truck will shift better, run cooler and get better MPG... Call and talk to these guys.
Dp Tuner
Stay away from the drugs with your 01... otherwise your PMR rods will (or could) go for a walk...
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
I don't think your in the mid 7's for torque. The hp and torque on the 01 was with DP tuners old 120 hp tune. The new 140 hp setting is way better!! I think you will run out of fuel with the stock system before 350 hp.
GOEGLEINBROS
Wright Cicty, MO
hey
It seems our mods are similar, but our programmers are diff. What type exactly do you have? I know on the 100hp setting on mine. My truck made 110 hp at the wheels and this was ona dynojet. On your 140 setting how much more power does it make?? I'll try to put the graphs up soon. The reason I was thinks mid 700s on the tq is because someone with my identical setup made 745 tq, maybe they were wrong. That's just what I read.
CSIPSD
Bend, OR
Most times TQ is twice what HP is... so 300 hp is most times about 600-650 tq. I bet the 750 guy had a nice shift spike in his dyno graph.
CSIPSD
Bend, OR
Stock AD's are 140cc but most flow somewhat less. There is no "HP" rating for them.
Stock injectored truck, no drugs, stock turbo... Top HP will be about 325. TQ about 675.
