id a tranny
rigdog43
Cuero TX.
hey ya'll
i could use some help.
i have a 97 f250 7.3 with a bad tranny and i need help to id whitch tranny i have . the best i can discribe it is (its real long , pan is shaped like the state ok. , the pan is bumpy-as in not flat , has the word metric ingraved in the pan in big letters.it is a 4 speed.
thanks! well i'm on my way out side to lay in the fire ants to get it out . exwife got the house and the 50 x60 shop.
i got the truck that didn't run . go figger!;tu
l8er .
rigdog43
Cuero TX.
thanks guys
was it the bumpy pan or just because its behind a 7.3?
will any other tranny fit?
thanks
E4OD was the only auto offered between 95-97, in 99 that changed to the 4R100 which is just an upgraded E4OD.
the only "easy" swap is to the 5 or 6 speed manuals, however the mildly dedicated will be able to put any transmission offered behind the T444 and T444E in international trim behind the PSD :stir
Even the 4R100 is not worth the hassle to swap in
silverF250
Arnold, Mo
Why not it's a direct bolt in. The only thing you have to change is the park/neutral switch and that isn't very hard.
changing the range sensor/ park/neutral switch to work in the OBS when a stock 4r100 is not tremendously stronger than an E4OD combined with the fact that if you choose to build an E4OD you put some 4r100 parts in there and there are some internal components that are stronger on the e4OD is what leads me to state that swapping the 4r100 is not really worth the effort.
silverF250
Arnold, Mo
I guess if your looking at it as spending the money to have one built then I'd agree. I was thinking he would look for a used one to swap with.
Milly333
