wrc123
Ok guy's I did some testing today and found that if I put it in drive pushed on the brakes and hit the accelerator there was no power from the turbo for at least 35 seconds shifted out of drive and into neutral. Did the same in reverse and got a different result there seemed to be a delay of about 10 seconds before it engaged and then the same as drive until I went from reverse to neutral the rev counter jumped to about 2000 rpm. If I rev the thing up in neutral its as if it is restricted. Can anyone help with this. Thank You. Paul.
02 f350 4x4 cc.
02 f350 4x4 cc.
