if a 7.3 does not start??
melmount
greensboro nc
Just checkign for info, If a 7.3 dioes not start, we can unplug the icp? that will set itto default. If it starts then, replace the icp? If it still does not start, it could still be injector not getting enough psi, right?
bad hpop?
do hpop's fail? Or is it all mechanical there? Example, just loose an o ring or something? Which causes pressure loss? What can go wrong with an hpop?
thanks
Yeah you can unplug the ICP. HPOP failure is very rare though it does happen. Make sure you are getting fuel. Smoke when cranking? CPS OK? IDM fuse OK? UVCH OK? Fuel tank got fuel? Fuel Pump operating?
Tbar
SDD STAFF/Moderator
Didn't you replace injectors recently? If so did you get it started after doing so?
Tbar
melmount
greensboro nc
one of em, i was just curious on this thread? trying to read and learn how this 7.3 works.
gained a lot of knowledge thanks to all you guys!!!
injector control pressure sensor...
on fuel rail in front of driver side head...
