Injector Drive Module (IDM) Trouble
forumpete58
Kansas City, MO
Hey guys after I thought I had my truck all fixed up I've gotten intermittent IDM problems. The truck will sometimes start and run fine, then all of the sudden (usually at idle) start running like crap. I hooked up my scanner to it and determined it was the IDM. Any thought on where to go from here?
Thanks!
forumpete58
Kansas City, MO
Is there anything I can do to avoid paying for a new IDM, I need it yesterday and I can't afford to buy one from ford.
Thanks!
Wood County Tx
not to pee on your parade
but the biggest killer of IDMs is ground or lack of it
this puppy has several grounds that must be met or acts like a bad guy
the most famous one is right behind the drivers battery on the inner fender
big fat GROUND that likes to come loose or be loosened when battery work or intake mods are done.
nother one is right near valve cover lower ground drivers side harness,
