injectors best place to buy?
93turbo_animal
Marengo,ohio
I need an injector wheres the best place to buy? and places to stay away from?
first rate performance diesel in TN?
pensicola diesel?
RoyBoy
Diesel Dork
central WI
pensicola diesel?
Stay away from them... my brother had nothing but grief with their rebuilds, one even had a cracked tip... truck ran worse with theirs than the old ones. stick with new alliant power injectors. They are more, but worth it ;)
if you have one injector that is bad from old age & wear then replacing it will give you one cylinder that is significantly stronger than the others and will show. Injectors are best replaced as a set.
If you're searching for a single injector then look at rosewood diesel, beans diesel, swamps diesel performance.
