Install optional parts into an 05 F350 DRW with XL decor package
HornetOne
Diesel ,Jet Fuel Addicted
Youngstown , Ohio
Hi everyone ,
Would like to know few things about an 05 F350 DRW with the XL decor package ,any inputs will be greatly appreciated .
I was thinking to put in pwr locks,pwr windows and adjustable heated mirrors from an 06 XLT into it .Does the XL model comes with all the necessary factory connections for just to plug in or do I have to connect them and run the wires seperately from a main power source .Is it worth it ...
Thank you in advance ,
HornetOne !
HeavyAssault
King William, VA
I doubt the harness will be there but you might find one that will work just from plugging it into the fuse panel.
Anything can be done given the time and money to do so.
IHC Power
STOCK STROKE
Walpole Mass
Sure
I just got through with the 05 mirror install on my 2001 350. There were 3 wires for the power mirrors then i had to run all the lighting wires. Then mounted switch under power mirror switch for heat, relay's of course. Now i'm all set, most of the mounting locations are the same but unlikely the harness's are in reach...
castellscl
