overworkedunderpaid
Okay, first of all I'm not real familiar with the terminology of some of these parts so bear with me.
I installed a ported turbo housing from Ron's and now I seem to have some concerns. The turbo seem's to be working fine, all I really have to go by is the "whistle" since that is considerably more present than before.
I don't have any gauges to really tell what's going on. Anyway, went on a 10 hour trip on a route I usually travel with a 28' enclosed trailer and this time time I had a small open trailer that weighed around 3k lbs. On hills I could normally pull at 65 easily on cruise I am now dropping down to around 58-60 with the cruise set on 65. No smoke, no surge, sounds like it should but it just slows down. Plus, the mileage has gone down considerably since the install and I've been trying to conserve to see how good I can get. This trip I got 8.5 and I'm used to 13-14.
Then, this morning I went to start it and when it started it made a sound I can't even describe and white smoke filled the parking lot for a minute, it was around 40 degree's. I drove it around for 15-20 minutes and the ebpv (I think that's what it's called during warm up) never kicked in.
I don't know what problems I could be having, the SE light hasn't come on, it does idle a little rough, almost like it has a cam. All I did was remove the turbo, send the guts to Ron for balancing and a new turbine wheel, installed the ported housing and new wastegate actuator (I think that's the name of it that bolts to the turbo housing) and reinstalled the turbo. I looked things over a few times and everything appears to be hooked up right.
Confused....
I like the way the turbo sounds but I'm not convinced everything is working right.
Confused....
