kingkevindavid
I am going to mount this inverter in my truck. I am just having a problem figuring out where I want to mount it. I have a couple thoughts: in the bed near the tailgate on the bed wall ( I have a cap on the truck ), On the transmission hump or under the back seat. any other thoughts? Also, as you can see from the pictures, this one is designed to to connect to the battery, use and put away. I want to hard wire it. I am thinking I should wire directly to the battery with 8 or 10 gauge wire, any other ideas on how to wire it? I will probably use 3M double sided tape to mount or make some straps to screw it down. It doesn't have any pre-drilled holes.
thanks for any ideas on how to mount it.
