Job #
dpantazis
#12
under the cheddar curtain
shamelessly plagiarized. ymmv
Job 1 Build dates 01-07 thru 06-07
  • First builds of the 08's. Lower valence in front on front bumper much shorter than later job builds.
  • Radiators would leak, most should be replaced under warranty by now. Also there was a recal for a venturi T to be added to keep the radiators from splitting.
  • TCM, early on it was thought that the transmission control module was a hold up for transmission life, but has sense been fixed by more refined trans tuning
  • Transmissions,Job 1 was the only model to have an external filter as well as the internal in the pan. some hard part differences like overdrive planetarys but i dont know all the details so hopefully someone can step in a clarify the changes.
  • Injectors had a recall for hanging open and filling the crankcase full of fuel, VIN specific recall
Job 2 Build dates 07-07 thru 12-07
Second build batches of the 08 model year
  • Got a bigger valence on the front bumper, said to improve mileage by 1-2 mpg.
  • TCM part numbers changed. Other small changes were made hopefully more can chime in with more info
Job 3 pretty much anything built in 08 was a job 3
2009
  • Job 3 added SYNC.
  • Last year of 3.73 gears as an option
2010s
  • 3.55s were the highest gear ration selection
Milly333
