Just bought 2000 7.3 how do i drain water
hammer450r
NJ
What are some things i should do maintenance wise, Thanks
Tbar
SDD STAFF/Moderator
This yellow valve is located behind and below the plastic cover that is over the fuel filter housing.(attached to the back side of the filter housing)
If you can find the metal drain tube under the truck and extend its length with a piece of rubber hose you can put a drain pan under it to contain the fuel.
Otherwise it is going to drain on to the frame rail and make a mess.
Tbar
whatabudro
Launched
Change the fuel filter while your at it with a motorcraft replacement.
hammer450r
NJ
is there one under that black cap or is it uner the driver seat by the frame rail?
Tbar
SDD STAFF/Moderator
On the 7.3 your drain valve is located on the back side of the filter housing under the plastic cover.
Tbar
hammer450r
NJ
Thanks guys i appreciate the help. Now if someone had a front license bracket id be set.
GTABurnout
Tell me how to get mine off and I will hook you up...
hammer450r
NJ
R U serious? Is it rivited in? u probably have to drill them out so let me know
