Just replaced front swaybar bushings now..
drchris1024 said:
I have a squeak. What can I do? :cussing:
Have you tried some lithium grease on the bushings to bar contact area?
Double check the torque at 35lbs at the bar and 85lbs at the stabilizer bar link.
Bill
hheynow
Señor Aceite de Soja
Northern California
drchris1024 said:
Do I have to remove to apply the grease or Syl-glide?
As far as applying the Syl-Glide you don't have to remove them. The aerosol spray will work its way inside. I have Energy Suspension polyurethane sway bar bushings and they came with a tube of silicone grease for the preliminary install. Periodically I spray them as well as the rest of the bushings on my truck.
Excellent suggestion on the spray :sweet
I couldn't find anything in the service manual for grease,spray,etc when installing the new bushings.
Bill
minerwelder
