lack of power in reverse
wrc123
escondido ca
Hey guy's, I am still having problems in reverse, the truck has no problems in drive it is real smooth, If I engage the truck in reverse and hit the gas it's as if there is no diesel getting through the truck coughs, splutters and misfires and then after about 15 seconds the engine revs clearly (as if its in neutral) and then its fine. Sometimes the thing just stalls when I first hit the gas as if the brakes are on and there is no power. It just seems funny how it can run just fine in drive and poorly in reverse. I had the cps changed, and had the tranny flushed and there was no improvement. I did discover at one time the previous owner had the edge juice installed, it is disconnected now but I have read somewhere that they had problems with trannys, has anyone got any info regarding this? Regards, wrc
Well I'm going to go with transmission problems (yeah great help right):tounge
if you had simply said that it takes a while to engage then I would say that you are having valve body problems or problems feeding the low reverse clutch. Given that it impacts the engine in a way that almost sounds like it is applying too much load (possibly binding one way clutch) to the engine at idle (not sure why the throttle would be unresponsive) because something is binding, once it spins enough to get it in the right place then the transmission is in neutral waiting for things to completely engage and pressure to build (there is a delay from the factory that gets more notable when components wear) and then it works fine.
I'm no transmission tech but that is my semi educated guess of the problem.
Not that knowing that helps you much but there are a couple things that you can do to confirm the diagnosis, all of which will result in you getting transmission fluid all over you and whatever you park over.
First pull the transmission pan, look at the level of black funk & sludge on the bottom of the pan. Some is normal like a thin layer just enough to make the pan look grey with a bit more around the magnets. if the magnets look like you stuck them in a box of iron filings then prepare for a new transmission.
Second is to pull the valve body off and clean it completely yeah you just had it flushed and if they power flushed it it is likely that there is junk helping bind a piston in the valve body thus sending fluid where it's not wanted until the valve unbinds each time. The valve body is all metal so once you get it out of the truck you can use brake parts cleaner to clean it up along with a small brush. I will suggest carefully removing each of the piston sets, one at a time and cleaning the bore and pistons. Pay careful attention to how they came out so you can put them back in the same order. (if not you'll have bigger problems)
If neither of these fix the problem then you're toast.
Oh and one last bit double check and make sure that the filter is seated in the pump correctly and the seal is good.
Zookie400
I WANNA GO FAST
wallingford, CT
this is such a common problem on quads.......they have a reverse rev limiter that shorts out. i could tell you how to fix it if it was a suzuki!
i once had a van in the shop that did funny things in reverse only......it ended up being a broken wire that would make contact when the engine was idle or under forward load, but cause an open circuit when the reverse torque would twist the engine over in the other direction.
also, check all of the ground straps from body/engine/frame/battery. a bad ground will cause the juice to go somewhere else, and the reverse torque may cause inadequate grounding.......maybe? its plausible :D
it very well could be a transmission issue, wich is tough to get deep into unless you are a tranny shop. id run with BJS advice to start anyway.
