Leak on top of engine
fgtex
Little Elm, TX
I have a leak on top of the engine. I have replace the orings on the fuel drain valve. I have cleaned the area up as much as possible to try and find out where the leak is coming from. I think that it may be leaking from the hose in the pic below. How do I fix this?
vbpgimage.php
Blue01F250
Boomer Sooner!
Ponca City, OK
Can't really tell from that pic if thats the problem --
but if it isn't -- it could also be your turbo pedistal o-rings or hpop o-rings leaking..both of which will leave shiny black stuff in the valley..
fgtex
Little Elm, TX
There is leakage around this fitting where it goes in to the valve cover. The leak could be somewhere else. I am just starting at the front and working my way back.
dpantazis
#12
under the cheddar curtain
looks like an after market HPX hose? a high pressure oil crossover hose? its an after market part, not ford OEM. they are good mods- to ballance the oil pressure between the cylinder heads.
the o-ring seals have probably gone bad. there is a finite life on the hoses too. if you did not put it on, it might be worth swapping out for the piece of mind.
look at the vendors who sell them for install instructions.
sinneD
Blue01F250
Boomer Sooner!
Ponca City, OK
That isn't an hpx -- the hpx is here on the other side of the cooler piping..
That hose he is referring to is an oem part, as it is the same on my truck :)
mp18d
Truckee, CA
So I have obviously been searching for clues about this PITA oil leak I have. I keep the motor pretty clean, but cleaned it again. It looks kinda dirty yet at the OTHER end of the hose mentioned on the pix. It terminates under the fitting shown for the fuel filter housing, going into what looks like the bottom of the housing. Same hose as shown in this first picture. HPOP??
If so, new o-rings from Ford?? :dunno
Thanks
Mike
