levelling kit and 37's
missingsc331
new kent virginia
i have an 05 f350 with 3 inch lift springs in the front and stock in the rear. i had the stock 18's with 35 12.50 bfg mt's, however, i sold the tires and wheels because a friend was selling the stock 20's cheap. do yall think i could fit some 37 12.50 procomp extreme at's with no probs
thanks,
Daniel
foxrider241
The Burgh
I'd have to say it may be possible and not. I have a buddy of mine who has a 05 psd and had 35's on it and only rubbed full lock barely. I have a 99 with a 6.5" lift and 38.50/15.50 super swamper boggers and they dont touch a thing. So not knowing much about how much tread you can fit under a newer ford i do not know but knowing my buddy fit 35's with little rub with no lift, i'd say they may fit with some rubbing but i dont know, thats up to you..
Fine69
Cranberry Twp,PA
I have an 05 with a front leveling kit and stock rear springs with 35's. I know there's no way 37's would fit my truck.
missingsc331
new kent virginia
yeah i had the 35's but with stock wheels and they didnt even come close to rubbing but now i have the stock 20's so im not sure if the backspacing is different or what ... thanks for the replies though
Fine69
Cranberry Twp,PA
I'm not running the stock wheels, these trucks do vary in height a good bit. Are you going to try to run 37's on the stock 20's? I believe the 20's are 8" wide, so you may have limited choices for a 37 narrow enough to properly fit an 8" wide wheel. Good Luck with whatever you decide to do, and be sure to post some pics when you're done.;tu By the way, love the color combo of your truck, looks familiar.;)
keanoknick
Big Stroker
Cowtown TEXAS
I have the Procomp Xtreme A/T's in 38.5x14.5 with 8 inches of lift and the rub, most recommend a 37 tire with 8" lifts, (on 05-07) I've seen a few on 6" lifts though, and they rub, so even with the right backspacing I highly doubt that you will get 37's to fit with less than 6" of lift.
missingsc331
new kent virginia
i understand that, but i have the 350 which sits what, an inch and a half higher in the back then the 3 inch springs in the front. i had 35 12.5 on the stock 18's now im talking about the same width just 2 inches taller still on a stock wheel ... and the 35's didnt rub at all ... i just like the look of a tall narrow tire that fills the wheel well
thanks
chuck416ex
warrenton,oregon
37's
i have 6" with 37".had to trim front bumper,and they rub just a little at full lock on tho steering,
