-BillLiftgate Trim Panel removal instructions;
Remove the interior liftgate handle trim covers
Remove the screws.
Remove the interior liftgate handle.
Remove the push pins.
Remove the lower interior liftgate trim panel.
Liftgate Latch Actuator Removal and Installation;
Remove the liftgate latch remote control.
Disconnect the lock cylinder actuator rod.
Disconnect the LH and RH liftgate latch cables.
Disconnect the cable conduit.
Disconnect the cable.
Disconnect the exterior liftgate handle actuating rod.
Open the locking clip.
Disconnect the actuating rod.
Disconnect the liftgate latch actuator electrical connector.
Remove the three liftgate latch remote control nuts.
Release the clip on the actuator.
Now Remove the liftgate latch actuator.
Re-install in reverse order
CHPMustang said:Heads up there dzl_x_4x4,a fellow Excursion owner provided this LINK to a retailer that carries the standard actuators for hecka cheap.
He stated he recently changed over all (5) of his actuators for about $30 and took about 30 minutes each to knock out![]()
DavidJ said:That was for the door, did you come across one for the liftgate? I haven't yet, but I appreciate the help. Thanks %)
