Looking at an 01 7.3L PSD...what to look for?
jamminGMC
"X" owner
Scott Depot, WV
Hey guys, new to the Ford diesel and am looking at an Excursion diesel. Unit has almost 100K miles already, but still very clean. What else to look for as far as dependability issues or absolute problems that ALL PSD in an Excursion have? Like I said, I am new to the Ford diesel arena and would appreciate all the help I can get. Thanks in advance,
jamminGMC:D
oi8228oi
another 99
OB NJ, land of traffic, stop lights, stop signs, a
Welcome
go on ebay and buy 2 or 3 Cam Position Sensors and keep one in your glove box. but the biggest problem is if ya start upgrading your truck your gonna get PMS(Powerstroke Mod Syndrome) and your not gonna be able to stop...
i love my 99.5 7.3 runs great no problems yet. and if ya get one just let us know and we'll help ya out
good luck
whatabudro
Launched
Sorry for the copy and paste but this should cover the bases. Some of this pertains to the different body style powerstrokes:
Here is a little reading for you:
Things To Look For When Buying A Used Power Stroke Diesel
Turbo:
You might take the air tube off the back of the air filter and look inside of it. If there is dirt build up, that is a very bad sign, so are the turbo fins looking sand blasted or bent. A little oily film is normal since the valve cover breather exits inside the tube.
Airbox:
Check the two bolts holding down the airbox lid. If they are plastic with a square recess, it is a recalled part. The recall is expired, but without the updated lid the risk of dirt infiltration is greater, the lid was updated with more supports and the updated bolts are metal with a straight slot.
Tranny:
If you buy a truck with an auto tranny, finding out if it's been maintained is essential, as the E4OD is an expensive transmission. Also, (if auto) seeing if the truck has an auxiliary transmission cooler would be worthwhile. For sticks, listen for clunking when shutting off or small vibration while operating. It could be an indication of a dual mass flywheel going out. Many have replaced them with single mass units.
Rear Gear Ratio:
4:10 will pull better, get slightly lower mpg’s and run a higher RPM compared to 3:55.
Coolant:
Ask the previous owner about the coolant - have they been adding FW16 or DCA4 to keep a proper SCA level? It is very important for stopping cavitation. You can get test strips to check the SCA level from NAPA, International, or Ford. I would test the current condition while looking over the truck, the SCA level should be between 1.5 and 3.0. Also, see if it has a block heater (it was an option on 97's).
Front end:
Check the front end for wear, or have an alignment shop check out the ball joints and steering linkage (tie rod ends). If they are shot, it is spendy (all four tie rods are around $400 just for parts, ball joint labor is also very spendy)
Oil:
The questions to ask are how often the oil was changed (at least every 5,000) and what kind of oil they used (diesel rated)? An oil analysis could tell you if there might be an engine problem or not.
Aftermarket stuff:
Seeing if the truck has got an aftermarket downpipe would be nice, a chip, or gauges (pyrometer, trans temp, etc.). Ask about any added items and who installed them.
Glow Plugs/Relay:
Find out if the glow plugs are in good working condition as well as the relay. Ask if either has been changed and when. You can check the glow plug resistance through the valve cover connector if needed and the relay should have power to both large terminals on top when the key is turned on, and one of the terminals should go out before ~2 minutes.
Injector o-rings:
The injector O-rings have been known to be a problem. The new o-ring sets have a pink middle seal. If the truck has an o-ring problem, one of the signs can be a discoloration of the fuel in the filter bowl. There is a drain on the passenger side front of the filter bowl for draining water (the filter is also the water separator) and you can catch some of the drained fuel in a jar – it should be dingy yellow and not blue or dark.
Leaks and Drips:
You can check the valley between the heads of the V8 for moisture and/or fluid. It should be dry not wet. Most leaks will run through this valley and down the back of the motor dripping off by the tranny/engine coupling.
VIN number:
If you take the VIN to any dealer, they can tell you when it was built, when it went into service, and some of the work that might have been done on it. You can also run prospective VIN's through Carfax.com to see the title history.
go to NAPA and buy test strips for the brake fluid and coolant, and check transmission fluid (swab it on a white piece of paper)... that'll give you a clue as to how good the driveline has been cared for irregardless of whether or not the body has been wash-n-waxed and interior detailed...
jamminGMC
"X" owner
Scott Depot, WV
Thanks for all of the help guys!! I was also curious as to what type of fuel mileage one can expect from a 7.3? Highway, city? I know it is all about the drivers heavy foot, just looking for a ball park idea. Provided the drivetrain has been descently cared for, how long are the 7.3's good for? Does the X have enough torque to pull a 9000lb travel trailer or will I have to start modding? Thanks again for your assistance!
jamminGMC:D
CSIPSD
Bend, OR
You will be fine with a 9k trailer. Mileage should be in the 16-20MPG, but they can very.
I have had over 270,000 miles on all Four of my PSD's before trading them off, My 97 I still see around town...
jamminGMC
"X" owner
Scott Depot, WV
ok, thanks for all of the help so far! I just spoke with my neighbor that has an 06 F250 with a 6.0. He said that the 7.3 is a turd compared to the 6.0. Is this true? Should I be looking for an X with a 6 liter?
jamminGMC:D
I personally regard the 7.3 as the better engine... but that's just my opinion, shared by some, not shared by others...
I wouldn't break my neck looking for a 6.0... if you get a better deal on a 7.3, get it. If you get the better deal on a 6.0, get that one instead...
mille-ryan
Loco Parts Changer
North Platte,NE
Id go with the 7.3 X, I just got one not long ago, jumping from the Duramax side and I like it a lot.The steering is my biggest problem, very sloppy and lazy.. workin on it though.
