Loose Connection on my 6.0 (what does it do)?
DA-HEAT
The First Stroker
Chaffee, MO
Yes basically same as 7.3 it is your exhaust backpressure sensor, what it does is measure what kind of ebp is being put out by engine and inputs that into pcm and pcm uses it to adjust the vanes in turbo for optimum performance and efficiency.
no-red 6 0
Senioritis
southmetro MN
silly rabbit-
that is where the blinker fluid goes..
just fill it up and your mileage will increase.
:lmao:sorry
hpprose
Sponsor
Granbury, TX
Yeah, that's the Exhaust Backpressure tube that runs to the EBP Sensor. If that's not getting the right back pressure, your mpg will be crap!
no-red 6 0
Senioritis
southmetro MN
food for thought here....
i perhaps should check MY connector...
but i doubt that is the cause....:lmao
F350DRW1
Waylon Fan
N.J.
Looks like EBPV tube going to sensor, Bama. I just saw your trashed turbo so it took me a while to get here. Man, when it rains, it pours in Alabama. Sorry for your string of luck that could turn goat p**s into gasoline. Hope you get it sorted.
