twt
I have a low (1 to 6 psi )boost miss. The fuel pressure is at 64- foot on the floor. Take the oil cap off & steady small stream of blow by.Miss gets worse with chip HP increase. Just put new injectors in to solve the problem. Can this be a computer problem - wiring or is this the $$ mechanical thing - rings or piston?? Thanks for all responses as usual.
I started the truck this morning ,died ,started ,died.... It was raining here this morning. I am starting to think electronicks, . Where is a good place to get the harness & valve cover gaskets from ?? Thanks ,T.Tolle
