Low boost problems
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
My truck has had the turbo cleaned, the egr cleaned, the pcm reflashed but the boost problems are still there. In stock mode I run 27-28 but if I put on any tune from my sct flash my boost goes down to 22-23 lbs. I get a blast of smoke at launch on the performance setting then just a hint of smoke after that. It seems to go good but why the lower boost? I reformated the tuner to the latest updates too. Is the turbo electronic activation system working right? Is it low fuel pressure? It was in the shop last week for a no start after it had been warmed up and driven a while. They drove it for a couple of days and it didn't do it for them and it didn't throw any codes. I wish it would just die then they could find out whats wrong. Any ideas on whats my problem??
f100cleveland
Southern Minnesota
Are all the sensors involved in good shape?
The dealer has had the truck 3 times for things related to boost issues and have had it on their scanner every time. They have taken it on 15-20 miles drives with the scanner hooked up takeing real time readings. Every thing checks out ok.
Milly333
