Magnefine filters
Brad B
Winnie, TX
Has anyone ever used any of the products from Magnefine? Looking for some feedback either good, bad or otherwise. I'd like to do what I can to protect my newest tranny I just had built.
Thanks
hheynow
Señor Aceite de Soja
Northern California
I had them for years in my truck. I change them every 15K. A great item for removing ferrous chunks from the ATF.
Brad B
Winnie, TX
Thanks hheynow. I'm surprised that no one else on this board has used them. Guess I'll order one, can't hurt right !!
firemediceric
Vero Beach, FL
I never used one. These are the ones that go in line before the cooler, right?
Is there a set mileage to change them at? How would you know if they become restricted? Do they bypass?
Oclip
So Cal
Magnefine Filters on PS/Hydraboost
Yes, we've been installing them in the P/S system when doing Hydraboost retrofits (on Hot Rods), to keep the old steering junk out of the new hydraboosters. It never fails, that the old steering box releases all that metal into the 'booster and we have to go thru the whole system again. The 'boosters are more sensitive to metal granules than the steering boxes. The best thing is to always put in a new box and 'booster, clean the lines and cooler if possible, AND use a Magnefine filter. As for their use in the Trannys, I'm considering that on my 2K F350, but for sure, one is going in my P/S system when I upgrade my OEM P/S cooler. I like their aluminum HP filters w brkt. They all work great! Oclip
Butch Cassidy
Chelmsford, Mass
Brad B,
I have been using them for 90k miles. I have cut open used ones (changed every 30k miles), the filter does trap the loose iron particles.
Butch Cassidy
Fire1
Certified Diesel Driver
Put one in my tranny line when I added an extra cooler a few moths ago.
