Manual Locking Hub replacement?
sierra4x4
California
Hello All Happy Thanksgiving!
I have a bad locking hub and need a replacement. Mine are labeled LOCK - FREE , what is the difference with the ones that are labeled Lock - Auto?
I need to order online as the nearest Ford store has closed up.
Thanks
RSG
Savoy IL
Happy TD to you too.
Lock/Auto means you have the vacuum lines running into the hubs and when you selected 2WD/4WD-Hi/4WD-Lo from the dash, it locks the hub. Lock/FREE means you need to get out and lock them in, or unlock them. When my old Ford auto hub dies, I replaced with Warn units, and I get out and set to Lock if I need 4WD. Note I still need to select 4WD inside the cab...
RSG
Savoy IL
john griffin
starvation lake,michigan
I found out how unreliable the "lock/auto" hubs were about 6 months after I bought my truck.The right side "auto" didnt disengage and that was the end of my front axel after a 300mile trip home.Ford replaced it all on warranty and a couple days later I put a set of manual Warn hubs on.That was 16 yrs ago and they still work fine!
FINKSTR
Pinckney. Michigan
A couple of years ago I was thinking about installing Warn hubs on my "01 dually and was told that they won't fit because of the hub extensions. I took a good look at it last week when I had the extensions off to replace the pads and rotors. I may be wrong, but it looks to me like the only difference between the dually and a standard truck is the extension. If so - other than being a little tight , which is true also of the stock hubs - I don't understand why the warn hubs won't fit. Anyone have any experience with this?
wyostroke
evanston/wy
The warn hubs(11690) will fit, but its near impossible to reach all the way in to turn them. I had a friend that did this, and he just built a little tool to reach in and turn them.
RSG
Savoy IL
IIRC, I had to knock the center of the wheel covers out but other than that I can reach right in and twist....
