MAP-Maximizer Ford 7.3L
Vinni
I didn't do it
Helotes, TX
Agreed - When you start to do upgrades (and you will) to the intake, exhaust and computer. The 7.3 will naturally boost at higher levels. Stock, I believe the 7.3 is throttled back to 17PSI boost; however, it is capable of 26-28PSI boost. This is a great increase in performance; however, without the MAP-Maximizer the MAP sensor will see the increased boost level and trigger the computer into a "limp" mode as if there was a mechanical problem and trigger a code.
The Maximizer removes the excess boost levels from the stream into the MAP Sensor in order to avoid AMP issues and the "limp" mode.
Works like a CHAMP.
Vinni
I didn't do it
Helotes, TX
My Fault
I thought you were talking about a product similar to ITPs Overboost Annihilator.
I believe what you are asking about achieves the same end; however, it does the job on the electrical side as opposed to the mechanical side like mine.
GOEGLEINBROS
Wright Cicty, MO
Last question this week. I promise. I got this Map maximizer in the mail with no direction. How/where to install?
platinum01
Willis, TX
Were did you buy the MAP Maximizer from? Have not heard much of this before.
CSIPSD
Bend, OR
I bet it just plugs into the MAP sensor, look at the pic here. Look at the White arrow, this is the MAP sensor, does your widget have a plug that looks like that?
