MAP sensor fooler
Dieselpwrdredneck
Addicted2Diesel
paris, Ohio
Anyone ever made their own pigtail?
Or would it be easier to just put in a relief valve?
tryin to get away from defuelin and limp mode, with out spendin alot
dpantazis
#12
under the cheddar curtain
you are better off making a pressure regulator instead of a blow off valve. loot at itp diesel's boost regulator. i don;t think you could build one cheaper.
You could install a Vacuum "T"* in the Waste Gate (red) line :dunno. Doing so, some of the Boost Pressure is bled off. The WG won't open as fast. More Boost, longer.
* A "BacK in the Day" Turbo/Boost Mod, when the 7.3 SD's first came along;):).. called it a Boost Tube.
