New Member mark williams
mustangmark
lachute canada quebec
hi guys how's it going? I have a shop here in lachute quebec. My own personal truck is a 2004 f350 superduty with a 6.0. Recently I'm having an int problem. I use this truck to pull my race car and it started to pop in the intake.Sounds like backfiring through the intake. No trouble codes and does not do it all the time. Stock turbo i have a air intake handn and a banks monster exhaust. Any help would be appreciated. My name is mark williams my shop is garage williams inc. I don't ussually work on diesels but seeing how it is my truck i would like to fix the problem myself. thanks
mark6403av
Phx A/Z
Welcome, I'm knew also. I would disconnect the EGR valve, and see if the problem is gone.
Glad you joined up here, Mark. Your EGR valve is plugged. You can clean it if you wish and run it or disconnect it. :SDD2
