max a/c question
chaddiesel
Kerrville/Texas
what is the difference between Max A/C and just A/C?
the only thing that I can notice is that the blower motor seems to work a little harder.
kwazyca
Sesquipedalian
Redding, CA
Max AC takes it's air from the inside of the cab.
Regular AC takes it from the outside.
There is a mod for Ford PSD trucks made before 2003 (I think that is the year) that helps get you cooler air when you select max AC. Made a noticeable difference with mine. Look here . Bob is a class act.
FWIW,
Tom
RenoF250
DungBeetle
California
MAX A/C recirculates, plain A/C takes in fresh air.
kwazyca
Sesquipedalian
Redding, CA
chaddiesel said:
thanks, on the dieselsite upgrade - where do you hook the vacuum line up to?
Inside the cab on the passenger side up under the dash.
kwazyca
Sesquipedalian
Redding, CA
chaddiesel said:
will there be other vacuum lines to look for?
No that is the only hookup as far as vacuum lines. If I remember right you splice it into a heater hose right by your fuel filter.
Believe me, it is really easy if I can do it.
Fill out your sig line so everyone knows what year truck and motor you have.
Helps others help you when you have a question or a problem.
Welcome to SDD,
Tom
RenoF250
DungBeetle
California
Yeah, it is pretty easy, the hardest part is fishing the hose through the plug in the firewall. It makes a noticable differince though. Mine needed freon also and now it is an icebox. I can't handle it on MAX for very long.
