Question Mirror Wiring
I just put some tow mirrors on my truck off of an '03 excursion. They bolted up fine and the connectors hooked right up, and the power works. The only thing that does not work is the blinkers (and I knew they wouldn't going into it) and I was wondering how hard it would be to wire it up.
Could I also run the wires so that the park lights will work as well? I know they didnt start having the park lights on them until '04, but was it just a wire that was added and not an entire change in the mirror?
Any guidance would be appreciated.
bambibandit
Austin, TX
I assume the mirror and truck both had a 10 pin adapter? or did your truck have a 4 pin or 4 pin & 2pin harness on it?
