Mirrors
King0581
Monroe, VA
JRJ04
Houston, TX
i just upgraded to those and love them. i wish the defrost and signal worked though. ive got an '02 and dont know how to wire it up
King0581
Monroe, VA
Did you get the factory OEM ones or ones like are in my link? Dont know if this link will help you? Its for the '08 tow mirrors but the wires in the truck should be the same.New Mirror installation Also here is this for the wiring inside a '03 model. Dont know how much different your '02 would be. For the heat you just gotta figure out which wire from the mirror is for the heat and run it to a switch on 12 volt wire or run them to a switch like I'm going to do. '03 Mirror Swap - All Done! - Ford Truck Enthusiasts Forums
JRJ04
Houston, TX
the ones i got were actually off an '03 excursion, but i cant imagine that itd be different. i'll have a look at those links. thanks!
King0581
Monroe, VA
The ones in that link where aftermarket and had some people tell me that the lens would viberate and other things so I went ahead and got the '08 mirrors.
