orion_134
Installing new PCM and 2" lift shackles on the front. Will I need new shocks for the 2"? I just bought new replacement ones, just need to know if I need longer ones. I don't do any four-wheeling.
Also, where is the PCM located? Do I need to unhook the batteries to exchange the PCM?
Also, another question: Working on an install of two electric fans with combined shrouds that will cover the entire radiator. Eaach fan has a diameter of ~16". With the fans on at highway speeds, will these fans actually choke the airflow? I know the MAX airflow will not be flowing through them, but I tow on flat ground and will ENOUGH airflow be going through them? They each flow ~3500.
Thanks,
Jesse
Thanks,
Jesse
