Motor Guard oil bypass system???
BigBadMarine
Laying in a wet southeast Texas rice field.
I just been reading about it. Sounds like a good filter. I would love to have a better oil filter on my truck. I am thinking about going to Schaeffer's oil, and just change it once a year, and the filter twice a year.
stroker21
Midland, TX
A lot of people are raving over the FS2500. I think that is the one I am going to go with. A little pricy but they package everything you need to fit to your year model pickup with pre cut hose lengths to make it a bolt on kit.
X-Hibition
Idaho
The toilet paper oil filter? I use the Oil Guard myself and am more than satisfied with the kit.
man id love to have one but its hard to justify the cost @ 400ish...thats
about 8 oil changes (driveway) for me just to break even. (not including
the periodic testing cost that id be doing).
and i know some of the systems had to install flow restrictors cause they
where starving the engines of oil (when they 1st came out for the
6.0L)
electryc_monk
Gestalt w/mild chaos
Highland Village, Tx
my "hay penny's worth"...
.,..as the value of 2 cents is different these days, right?
OKAY after nearly 2 years of research into oil bypass filtration and CCV filtration I've finally had spare time to install a version of the Motorguard bypass setup on the 7.3L. Two months ago I got the Motorguard installed on the better-half's Jetta (TDI). Have oil samples ready to be sent off to ANA LAb's too. [That is when I get back from a road trip to Michigan- *Family Drama*]
So here are a few pictures of the setup I put on the 99 F350 as of this morning....F-I-N-A-L-L-Y.
For what its wqorth, I have a list of all parts extra I had to purchase and their cost... so I can give ya'll a grocery list for future folks to install.
*** The oil leaking down the engine near the bypass lines is from the HPX-mod that i did simoltaniously. I went to the local folks and had them fab-up a hose for the High PSI crossover... all told it only cost abou $30 after taxes.
pictures will also be below as well.... I had to get a 45 degree modd to the setup due totally to the turbo mouth was in the way! LOL
