Motorcraft battery
RSG
Savoy IL
5 years ago I put in a replacement set of batteries, I think the original was bsd65 but the ones I got from a dealer for about $100 each were bh65 (900 cold cranking amps-CCA). I recall that they were changing to a lower CCA, and discounting the batteries I bought.
I got one bad cell and am shopping for a new pair now. Ford now shows a 650 CCA or a 750 CCA for this truck, under the bx665 series. They have an 850 CCA that I would instead choose; stock price seems to be $120 at 2 dealers in the area. The warranty has changed from 48 month replacement to longer, but full replacement on first 3 years, then pro-rated out to 60 or 72 months, I forget which.
Looking for replacements on sale. Also curious your thoughts on why they've reduced the CCA "needs" for this 7.3L engine?
I sold batteries for a few years a long time ago, and I always sold the most CCA
that they could afford. Cheap batteries and big cubic inch engines don't go together.
So get the biggest one they have.
X2 on what Doug said.
A 444 CID High (high) Compression Deisel needs all the cranking Amps we can muster.. When it's Cold Outside ? Not to mention what Amps, 8 Glow Plugs pull ?
:dunno
I preach what WD40 is selling. Get the BIGGEST batteries that will fit the battery boxes!!
Dave:thumbs
RSG
Savoy IL
Yeah, guys, I fully agree. I'm just pointing out that Ford is promoting a much smaller rating as direct replacement. Seems crazy.
Also hoping someone knows about a price better than $120 each on the 850 CCA, or a good alternative to Motorcraft. I've gotten variable results out of Interstate batteries, both great and lousy.
IDSTROKER
Blackfoot ID
Blackfoot ID
i Just bought some 65-60p batteries from Excide they were 1000 cca and 850 ca what a difference it make's I only payed $ 88.00 per battery.
Since replacing my stock batteries in 2006, I've stuck with the 850-900 cca Kirklands from Costco which run about $80 or so each. ;tu
RSG
Savoy IL
Just FYI...Current prices here in beautiful central Illinois:
Interstate: 850 CCA, $136 no discounts ("Even Farm & Fleet has more expensive batteries" :tounge)
Ford: 850 CCA; $120; 3-yr replacement; 72-month total warranty
Autozone: Duralast Gold 850 CCA; $123; 3-yr replacement; 72 month total warranty
NAPA: Legend series 7565 880 CCA; $114; 3-yr replacement; 75 month total warranty...website shows this to be a 675 CCA and higher price.
Sears:
1. Diehard platinum. 930 CCA; $220 with 4yr full replacement.
2. Diehard gold. 850 CCA; $125; 3-yr replacement; 100 month total.
Battery Specialists and Golf Carts (yeah, I know): 850 CCA/1100CA; model UE65; $64.52; 6-month replacement; 12 month total.
