My engine dies from time to time!
clem
N.E.Ohio
Your fuel bowl could have a pin hole on the bottom from the inside. When you get your new filter,drain the fuel bowl discard the old filter. Take out the plastic stand pipe with a 7/8 inch crow's foot wrench(threads are left handed turn clockwise to loosen).Unplug your fuel heater element from the inside take it out and inspect(they are noted to go bad often and blow the #22 fuse).Use some cotton swabs to clean the screen between fuel bowl and FPR from inside.Clean the bottom of your fuel bowl and look for any pitted spots on the bottom.If there is a hole you can repair it with a product called J-B Weld,it is epoxy that can have contact with fuel.If you can"t find the right epoxy send your address I can mail you some.Reinstall fuel heater,standpipe, filter and lid.
The fuel pump is only a mechanical pump that runs off the cam I don't think there are any sensors on the pump.
No check engine light with a bad CPS.
Make sure your fuel cannister drain valve isnt causing the leak, sometimes just the slightest nudge will cause a drip on the drain valve or you might also have bad fuel hoses on your fuel pump causing the leak. Over time the hoses can get weak and dry and develop a crack. And as Clem mentioned, the CPS rarely sets your check engine light.
bartman
Dallas, TX
Welcome to the SDD forums Janusz! It appears that you may be dealing with two issues: one could be a dying cam position sensor (it's one thing that you need to have with you anyway) and two, the fuel leak. I know that these fellows will be able to help.
Ja jestem tutaj w Dallas od 1983 roku, i ja jestem troche w szoku ze ktos w Polsce ma powerstroka. Mam nadieje ze pana problem bedie szypko naprawiony i ze pan bedie utrszymywal kontakt z nami prszez internet. Jesli ja bede w stanie panu pomoc jakos, niech pan mi da znac. Powiem tesz, ze pana angielski jest lepszy nisz moj Polski.
Bartosz
