Question my modified sb intake
ferdtucks
sean
oregon
i decided to use the zoodad mod a little better and make it a DIY cold air LOL i just connected from the zoodad and tapped into the sb intake and added a scoop for the air behind the grill. the duct tape is just for a good seal the tube is actualy inside. my question is
1. is this usefull? and 2. the sb intake comes with a clear cover for the top of the intake box i was told to take if off so it can get as much air as possible but would it benifit me to put it back on since i kinda have a cold air effect?
Fire1
Certified Diesel Driver
I would put the cover on with your set up. It should keep the cooler air in and the warmer air out I would think.
ferdtucks
sean
oregon
ok thanks guys i had been running with it off for a good while thinking it was better
big bear
west plains, mo.
s&b cold air intake mod.
i have the same set on my 01 f-350 and i was wondering if this helped any and if so, what was the results. thanks!!!
ferdtucks
sean
oregon
i think i noticed a little better spool up at higher speeds like 40mph up i also did the ccv mod that may have added to that.... did you?
big bear
west plains, mo.
ccv
nope, haven't done that yet , just the 203 stat., boost fooler, and the hp crossover and the 4 in. ext. from the turbo to the end along with the s&b cold air kit. keep me posted and let me know hows things turn out.thanks for:tounge the come back!!!!!
