My new Wheels and Tires
NDsuperduty
Kingwood, TX
Decided to stick with 18's to save money and 35's since the people at 4wp said 37's would rub like crazy. I still think there is enough room to fit, but they are the professionals.
Before
After
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
Looks good. It looks like you could put 37's on it. My 35's don't rub with a 3.5inch leveling lift. Your front right tire is on backwards as the Extreme AT's are directional.
NDsuperduty
Kingwood, TX
EDIT: just checked the tires and your right. I wish they would have told me that when I bought them.
platinum01
Willis, TX
Looks good. Starting to like the look of black rims. Good looking set up that you have there.
NDsuperduty
Kingwood, TX
I have dropped my rear tire pressure to 38lbs, and I still seeing the dirt in the mddle of the tread. There is about 1" clean tire on each side of the tread. Is there any reason why I should not drop it lower to get even wear?
f100cleveland
Southern Minnesota
You can put a chaulk line across the face of the tire then see if it wears off evenly to check tire pressure too. I have been down to 35 in the rear and 45 in the front but mileage will suffer compared to 50-60lbs. When I pull the trailer I go 70 in the rear and 65 front.
NDsuperduty
Kingwood, TX
I know that it needs to be lowered if its going to wear evenly, but I wasnt sure if the weight of the truck itself made it an issue. I pull a trailor maybe twice a year and usually its no bigger than a 12-16' double axle.
