1goug76
I have a 2002 srw w/ factory 3.73 ratio. As you can see by the info in my sig. I need to change my ring and pinion in both axels (trannys are getting expensive and the 38's aren't helping things out much) My truck is sitting right now with a lunched torque converter, maybe even a tranny, dont know yet havent had time to pull it out and investigate. Anyway while I am fixing that problem I figured I would change to 4.56 gears. Do I have to change carriers to go that low? If I do what is the lowest ratio I can go to without changing carriers?
