NEED HELP. TRUCK WON'T START. HAVE TO GO TO SCHOOL.
whoa, austin texas and you have to plug it in ?
sounds like maybe youre glow plugs arent workin....
ranaumo
Diesel Junkie
LA - Lower Alabama, part of FL
GPR and or GP
I agree with Bushpilot.
When you turn on the ignition, does the battery gauge drop, then rise up after it runs a bit?
If not, then it may be the Glow Plug Relay not fireing the Glow Plugs (easier to check and replace). Can also check with a meter across the terminals and have someone turn on the ingition. It should allow current to go through, then shut off.
The glow plugs can be checked through the valve cover harness and a ohm meter. Off the top of my head, I do not remember what the good values are, but it does help troubleshoot which ones are TU.
Ron
strokin'_tatsch
death row inmate #7
Austin, Texas
well actually come to think of it. the battery guage usually does come on then drop then come back on after it runs for a second. but it didn't do that this morning. how do i check it. where is the relay located?
strokin'_tatsch
death row inmate #7
Austin, Texas
well now when i turn the key on the battery does like normal. goes up then down a little, then after running a little bit it goes back up. i don't know what the problem is but i will try the gpr or gp. and see if it gets better. i had to plug it in for about 20mins. this morning before it would start.
clem
N.E.Ohio
If you had to plug it in to get it started its prolly a bad or weak GPR.
strokin'_tatsch
death row inmate #7
Austin, Texas
but how come when that happened the battery gauge didn't do like normal but now it is? i will get some guys around here that i know to help me jerk everything apart one of these days.
AlaskaRedneK
Chugiak, AK
Glad to hear ya got 'er runnin.
But if that happens again, have someone "jump" the two tall posts on the relay for like 20 sec, then try to start it, if it works, then thats yer problem.
Best of luck,
-Matt
dserge66
