need some quick help, probably CPS??
paulkeith
Da A
ok,
2002 7.3L manual, 120k miles, i think original cps.
I'll be on the interstate just cruising around 65mph, and i get a real sudden power loss, and it picks right back up and keeps going.
lately the power loss has been more pronounced, and sometimes longer or kind of a rapid stutter. yesterday and today it has stuttered like this and then thrown a check engine light.
if i shut it off and restart it, the CEL goes away. driving a few minutes ago, it stuttered, threw a CEL, and then completely died, but started back up and the check engine light stayed off.
I have a replacement cps in the glovebox, is this most likely the problem?
thanks fellas
Paul
Tbar
SDD STAFF/Moderator
If you have a performance chip in the truck............pull it and see if the problem goes away.
Tbar
Tx_Atty
Master Baiter
Fishin'
if you dont, I would bet cash you have a cps problem. Your symptoms sound just like when mine went out. If you have a code reader, see if you have a cps error code.
paulkeith
Da A
well, i replaced the cps and now it runs really well. better than it has since i've owned it.
file this one away under shatty cps.
thanks to all who helped.
paulkeith
Da A
i had one in my glovebox from advice i read before..... golden.
