New Bio-Diesel System
Vinni
I didn't do it
Helotes, TX
I finally got my new bio-diesel system set up. Still going through a few modifications though... made my first 44 gallon just yesterday and pumped 30 of it into the tank. Wanted to leave a bit off the top just in case i run into a problem so i can still pump in pump diesel if needed.
MySpace
Tx_Atty
Master Baiter
Fishin'
is the myspace link supposed to go to a picture? I just get auto redirected to the home page for myspace.
bbressler
Happy, TX
Looks good! I'm interested to see how the PVC holds up...will you keep us updated?
Vinni
I didn't do it
Helotes, TX
The PVC should hold up as long as it is in-place at my residence as long as i plan to stay there. Eventually, it will get torn down in order to move to another location at some point in the future.
I filled the tank last Thursday with my Bio_Diesel creation and drove the truck to Del Rio and back - ran great and actually got about 18MPG through the hill country.
Still making modifications to the system and the mixture.
Will keep you updated
bears4x4
grease monkey
katy texas
would you mind if i ask how do you do your process, i trying to find one that has been tryed and works, ?
Vinni
I didn't do it
Helotes, TX
My Process:
I pump 36 gallon WVO from the blue barrel on the right (WVO storage & initial strain through pantyhose) to black barrel on the left. I then plug in my 220V heater element and turn on the recirculation that pumps from the bottom to an aerator in the top. While that is heating up and circulating, I mix up 8 gallon of Methanol with 1 3/4 cups Lye and dump that into the heating WVO. Once the mixture reaches just over 125*C (as evident by the candy thermometer) i unplug the heater element and allow the circulator to continue for an hour. Once the hour has expired, I unplug the pump and shut off all of the valves-isolating the WVO/Methanol mixture to the heated barrel.
I allow this to sit for 10-12 hours and work its' magic. Once the incubation time has expired, I drain off the glycerin (byproduct) from the bottom of the barrel into a 5 gallon container. This leaves me with approximately 40 gallons of usable bio-diesel for use in my X.
I then adjust my inline-valves to remove flow from the circulator to the filters. I run the mixture through a 10 micron and 5 micron filter set into a sealed 55 gallon drum (sits on far left side). This is my usable fuel storage. Once my fuel gauge reads at 1/16th of a tank, i run a line from the garage to the truck and pump the fuel from the sealed drum - through a Goldenrod water block / 5 micron filter - to the truck.
Ready to roll at about $1.15 per gallon.
bears4x4
grease monkey
katy texas
not to ask to many questions
where do you get the lye,
whats the lye labled as ,
i have a place to get the Methanol now...
ill have a pic up of my system when i get it running next week, its not glued together yet and im missing my heating element
bbressler
Happy, TX
Do you wash your finished biodiesel? It seems like you must be getting some methanol into your biodiesel to have more biodiesel than you started with as oil.
