No Crank/No Start in Park
makuloco2000
USA
Forgot about this common issue with the Superduty and Excursion vehicle that while it won't leave you stranded, it is a pain to live with. It has to do with the shift linkage bracket bolts coming loose and losing the shift cable adjustment as a result. Check out the video, as you will likely run across this at some point in your ownership of the Superduty. I hope my video helps!
https://www.youtube.com/watch?v=FD9AhzZOCcY
Stroked68
This is FORD Country
Eudora, KS
Been there, done that haha. My bolts were loose and I had to replace the plastic bushings in mine. Recently I thought my tranny was bad cause when I put it in drive (according to the gear selector in the dash) It wouldnt do anything! Well it was really in neutral. So now the D position is really the 2 position haha. Need to adjust my cable. Lazy and havnt done it yet haha.
makuloco2000
USA
Yep both problems are very common.
