Strokin_Early_99
Diesel Youngin'
I have a no start situation. IRP at 65% and ICP at 150-160psi while cranking. I have pulled the injectors and replaced the O rings so they are good. I am thinking it is an IPR issue. I have pulled the stealth pumps and blocked off the front IPR so it will not have to be removed again to diagnose a dead IPR. The shaft is fine, not broken. The pumps turn smoothly without any weird feelings or noises.
Is there such a way to bench test an IPR?
Is putting new O rings on an IPR the same as getting a new IPR?
Is there anything I can do to take the IPR apart and clean it?
If I throw an new IPR on the sucker and it will not start, what else could it be?
Thanks,
Howard
(Multiple listed)
Thanks,
Howard
(Multiple listed)
