Question No start
butch2000
michigan
Hi , all , I am new here, 04 6L , so I am driving down the road , pull out to pass and the truck just shuts off ?
coasted to the side of the road , the truck won't even turn over ? towed it home , the banks PDA says no communication with the PCM ? checked all the connections all good ? turn the key on all the dash lights etc come on ? turn the key to start position and the starter will not ingauge ? checked all connections at starter all good ? does the PCM control the the starter as well ? the relay under the steering wheel knee panel is clicking when the key is turned ? help ? lots of battery power to ?
Clean the Battery cables and make sure the Batterys are real hot, one may have a
short in it. Check them one at a time.
trailey97
had the same problem... unload your banks and then see if the truck starts. i have a pmt and i unloaded my pmt and my truck started right up, then i reloaded it and everything is still fine.
butch2000
michigan
bad relay, but ? had it running revved it up couple of times now it won't move ?
