noise is back!!!!
atk
Moderator
simcoe, ontario, canada
i seem to be getting some noise from my turbo, between 0-5 psi of boost. took it to the dealer few months back for the same concern and they said turbo was fine. i did notice at that time, i could move the compressor wheel up and down about a 1/16 of an inch. to me it seems like the comp. wheel is hitting the housing. also the noise seem to have gotten worse after i did some exhaust work....:sly ....from what research i have done, there should be no movement in the shaft that the comp. wheel is mounted too....the tech told me some movement is normal, i think it is excessive....does anybody have any ideas? might have to take it back in, but i will have too find the kitty first...:doh: .... any feedback would be great.....
alex, sounds to me like your turbo is ready to go. what you sayin sounds alot like what mine was doin. it had too much play as well. plus a loud squeel
Svttim
