O-Ring guide ?
NevrKnow
Aiken,SC
Anyone have an o-ring size and/or location chart? Was starting on one and said "duh" one of my fellow members may already have one to post. Just a thought.
dboyw
Lancaster, PA
No guide, but these are are a few that I have saved.
I'm sure you already have them, but I like to think that I help somewhere.
Fuel drain valve 2 #202 1/4 ID x1/2 OD x 1/8 W
Pedestal 2 #205 7/16 ID x 11/16 OD x 1/8 W
2 #211 13/16 ID x 1 1/16 OD x 1/8 W
from the OBS parts list, most will apply except for the fuel filter applicable ones.
Fuel System O-Rings (use Viton for fuel)
#123, 94-95 FPR Bowl
#025, 96-97 FPR Bottom plug, outer (seals plug to housing)
#110, 96-97 FPR Bottom plug, inner (seals fuel return to HP side of pump)
#012, 94-97 Water In Fuel Sensor Probe
#014, 94-97 FPR
#015, 94-97 FPR to Filter Housing
#011, 94-97 FPR Screen Plug, Smaller o-ring
#012, 94-97 FPR Screen Plug, Bigger o-ring
#018, 94-97 Fuel Heater Connector
#202, 94-97 Water Drain (2 required)
#???, Fuel rail end plugs in head
Oil O-rings (use Buna-N for oil (Nitrile)) (70 durometer is standard, use 90 durometer for the HP Oil fittings)
#013, Oil Rail Plugs, ICP, and HP hose Fittings (90 durometer)
#012, Dipstick tube to Bung (70 durometer)
#216, Oil Rail Galley Plugs ???
#010, CCV, small o-rings (70 durometer) (2 required)
#???, CCV, large o-rings (70 durometer) These are currently 3 sided, get from International (2 required)
#140, HPOP Rear cover
#205, Turbo pedestal o-ring, large
#211, Turbo pedestal o-ring, small
#117, CPS o-ring (70 durometer)
#???, Oil Cooler o-ring, inner
#???, Oil Cooler o-ring, outer
#140, Turbo to Y-Pipe (140 fits, stock is a Quad ring)
#???, E4OD Dipstick tube o-ring
Coolant O-Rings
#???, Thermostat Housing
#???, Lower Inlet Pipe (later Pump)
#???, Hose fitting (later Pump)
O-Rings, Individual OEM
Camshaft Position Sensor (CPS) O-Ring
(Ford) F81Z-12B615-BA
(International) 1824948C1
Crankcase Breather (CCV) O-Rings
(Ford) F4TZ-6769-A (small; seals screw head; 1/pack)
(Ford) F4TZ-6769-C (large; seals breather adapter to valve cover; 2/pack)
(International) 1824452C2 (Small, 2 needed)
(International) 1820784C2 (large, 3 sided, 2 needed)
Dipstick Tube O-Ring
(International) 875519C1
Fuel Rail End Plug O-Rings (the small 1/4" square drive drain at ends of heads )
(International) 1815734C1
High Pressure oil rail o-rings For rail plugs, elbows and ICP
(Ford) F4TZ-9N693-A
(International) 1815874C1
Oil Cooler O-Rings (2 each needed)
(Ford) E3TZ-6C610-A
(Ford) E4TZ-6K649-E
(International) 1807563-C1, Inner
(International) 1804414-C1 Outer
Thermostat Gasket (o-ring)
(Ford) F4TZ-8255-A
(Intl) 1821880C2
Turbo Compressor Outlet to Y-Pipe O-Ring
(Ford) F4TZ-9E436-A (94-99)
(International) 1818372C1
Turbo Pedestal O-Rings (between pedestal & block; pedestal & turbo)
(Ford) F4TZ-6N653-A & -B
(International) 1815560C1 Turbo to pedistal O-ring .421 x .560
(International) 1815561C1 Turbo to pedistal O-ring .769 x .908
Water Pump Inlet Pipe Gasket (o-ring)
(Ford) F81Z-8255-AA
NevrKnow
Aiken,SC
Thanks guys, I have some more and missing part numbers. Also some numbers for those ford parts so we can get them ALL alot cheaper hopefully. Just got disgusted when I saw someone offering 2 ! o-rings for $17 when I got a whole freaking bag of them from McMaster Carr for 5 bux!!. I'm also thinking of just making a standard list to order from them with only what we PSD owners need. Or else buy 1 bulk kit and divy it out to other members. I'll let ya know what I find out.
springerpop
SFV, CA
Alan Miller started one, then kinda' went dormant. Some of us have added to it and placed it in several places in cyberspace. Be aware, the chart is for 7.3's, not 6.0's.
Here's where I put mine:
Powerstroke O-Ring Chart
Pop
NevrKnow
Aiken,SC
Getting the camper ready for the race in Charlotte this weekend, but hopefully I can still get this done before then. Thanks for all the input. Yea, i'm a slow typer so it will take me a few to seperate the 7.3's from the others. But it will definately be worthwhile to me and hopefully someone else may find it useful in the future. :)
