OK, really dumb question about charging batteries
TXCobra
Georgetown, TX
With our two battery setup, I thought there was something about unhooking one of them to charge it if you plan to leave a trickle charger on it. Something about the way they are run in series? So my question is, if I wasn't going to drive the truck for a couple of weeks (or longer) and wanted to keep the batteries charged, could I use one charger that I switched between the batteries every few days or so, or should I use one for each battery? Do I need to do anything special (like unhook one of them)?
Wood County Tx
fer years i used a trickle charger one lead on the pos of the one battery and the negative on the negative of the other battery.
then i got lazy and just put the charger on one battery
came home a few weeks later and she was still charged up
as long as both batteries are equal in age and strength you should be okie dokie
bbressler
Happy, TX
+1.
Our batteries aren't hooked up in series, they are hooked up parallel -- so your charge will go to both of them If they were in series, you'd have 24 volts.
What you have is one battery, in two places. Treat it just like one battery. Charge them both and replace them as a pair when the time comes. Changing only one battery will shortly kill the new battery in a short time.
2ndPowerstroke
Ford Driver
Oregon
As for powerboatr`s post (same thing kinda) --my 12v parallel camper batteries were setup on the solar panel trickle charge the same way--negative on one batt, pos. on the other --never a problem there. Then I pulled the batts out and when I put them back in I hooked up the panel on only one battery--didn`t notice a difference. Never tried it on a dual battery truck???
If it`s gonna be sittng long enough to be a concern I`d have to say better to pull the batts and bench`em.
Oh and I would also be really careful if you hooked one battery where you laid the battery cables since the other batt would have juice and also a possible power source depending on how you unhooked them (know what I mean).
OK, see...that's what I had heard before. So I really do need two chargers then.
No! You did not get what I am saying. Why would you use two chargers on a battery? You only need one charger. What happens to one, happens to the other battery.
rock_doctor
Member
hello, PJ
Two batteries hooked in parallel behave as one big battery. Treat it as such. Hook the charger to either battery and both will be charged just like when you turn the key the starter pulls from both batteries. It isn't a boat with an isolator or house batteries or what ever. If you are going to leave it for a couple of weeks i would not worry about it. if you are going to leave it for several months then you may want to pick up a good computer controlled maintenance charger. Hook it to either battery, plug it in and don't worry about it.
2x6 bulldog
Buford/GA
Just put the charger on one battery and both will be charged. They are wired in parallel.
