Overhead console intermittent
airdrew99
Living for Him
Brandon, MS
I've repaired the overhead computer on my 2000 PSD, but now my brother just bought a 2001 PSD. His overhead computer/console is intermittent. It seems to work good then get extremely dim, even without the lights on. The link for the overhead computer at forgotton.net is not working right now. Does anyone know of a different link or website?
Also, his dome light works when you turn the switch on the dash, but not when any of the doors are opened. Any ideas for fixing this?
Drew
IHC Power
STOCK STROKE
Walpole Mass
Trip/Dome
The trip computer is cheap at the dealer, about $75 unless you soldier all the little resistors and capacitors that got fried. Easy fix on the dome lights unless a switch is bad try spraying a good penatrating oil into the latch/hinge assembly and then repeatedly open and close all the doors quickly, they stick over time and this should do it. You might have to get the door panel off and spray the inside too.
clintusaf
Clint
Bossier City
i have the same exact problem with my overhead display. if i push the tinted plastic piece, it makes a popping noise and shows for a second and then fades out. the link that i have found on here for the fix doesnt seem to work. hopefully someone will chime in with a fix. ive been meaning to get mine fixed for a while now.
Smoky
Mississippi State
I wish someone would come up with a fix on the overhead console to correct the DTE. I can fill up completely and it'll say about 250 miles but I can go 521.
:dunno
Red Monkey
Alabaster, AL
DaveBen is correct, there is no fix for the Lie-O-Meter. But, there is a fix for the dimming of the display. It's caused by the resistors comming loose. Just take it apart are re-solder the resistors and you'll be good 2 go.
Milly333
